必要な工具と部品
Using the Phillips 1 screwdriver, remove the laptop's back panel.
The parts you see underneath that panel are called the laptop's "internals".
Using the Phillips 1 screwdriver, remove the six screws that hold the audio board in place.
Hint: the sixth screw may not be readily visible. It can be found in the bottom left corner of the audio board, under a small black flap.
With the screws removed, the audio board can be easily lifted out.
もう少しです!
終わりに
