メインコンテンツにスキップ
Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement
必要な工具と部品
  1. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement, Back Cover: 手順 1、 1の画像 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 2、 2の画像 1 Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 2、 2の画像 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 3、 3の画像 1 Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 3、 3の画像 2 Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 3、 3の画像 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 4、 1の画像 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement, Hard Drive: 手順 5、 1の画像 1
    • Slide the hard drive out of the SATA port and remove it from the device.
  6. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement, USB Port Plate: 手順 6、 1の画像 1
    • Remove the two 5.0 mm Phillips #1 screws shown.
    • Remove the two 3.0 mm Phillips #1 screws shown.
  7. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 7、 1の画像 1
    • Using a plastic opening tool, pry open the hinge shown until your fingers can fit under it.
  8. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 8、 1の画像 1
    • Pull the hinge the rest of the way up.
  9. Asus Vivobook Q301LA-BHI5T02 USB Port Plate Replacement: 手順 9、 1の画像 1
    • Disconnect the plate from the shown connector. The USB port plate is now disconnected from your device.
終わりに
作成者
1人の作成者と共同作成されました。
Kevin Kochanek
メンバー登録日: 11/06/18
181 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G3, Gulbrandsen Fall 2018人のメンバー
UMASSD-GULBRANDSEN-F18S5G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 201
