メインコンテンツにスキップ
Asus Vivobook F510UA Hard Drive Replacement
必要な工具と部品
  1. Asus Vivobook F510UA Hard Drive Replacement, Removing the bottom panel: 手順 1、 2の画像 1 Asus Vivobook F510UA Hard Drive Replacement, Removing the bottom panel: 手順 1、 2の画像 2
    • Turn your laptop so that the back panel is facing you.
    • Remove the large gray rubber pads.
    • Remove twelve screws from the bottom of the laptop using a Phillips #0 screwdriver.
    • There are four different screw sizes.
  2. Asus Vivobook F510UA Hard Drive Replacement, Screws under the rubber feet: 手順 2、 2の画像 1 Asus Vivobook F510UA Hard Drive Replacement, Screws under the rubber feet: 手順 2、 2の画像 2
    • Remove the screws from beneath the rubber pads using a Phillips #0 screwdriver.
  3. Asus Vivobook F510UA Hard Drive Replacement: 手順 3、 3の画像 1 Asus Vivobook F510UA Hard Drive Replacement: 手順 3、 3の画像 2 Asus Vivobook F510UA Hard Drive Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
  4. Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: 手順 4、 3の画像 1 Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: 手順 4、 3の画像 2 Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: 手順 4、 3の画像 3
    • For precautionary purposes, we advise that you disconnect the battery connector to avoid any electrical discharge.
    • Use plastic tools to avoid damaging the battery, which could leak dangerous chemicals or catch fire.
    • Using a fingernail or spudger, move back the retaining clip holding the battery connector in place.
    • The battery connector is very fragile. Proceed with caution.
    • Put a spudger under the battery connector and twist, to lift off the connector.
    • You may want to look at the battery disconnection steps for Asus Vivobook F412DA: Release battery connector, which are the same as for this model.
  5. Asus Vivobook F510UA Hard Drive Replacement: 手順 5、 3の画像 1 Asus Vivobook F510UA Hard Drive Replacement: 手順 5、 3の画像 2 Asus Vivobook F510UA Hard Drive Replacement: 手順 5、 3の画像 3
    • Remove the four screws from the hard drive using a Phillips #0 screwdriver.
    • Peel off the tape covering the end of the hard drive to reveal additional screws.
  6. Asus Vivobook F510UA Hard Drive Replacement: 手順 6、 3の画像 1 Asus Vivobook F510UA Hard Drive Replacement: 手順 6、 3の画像 2 Asus Vivobook F510UA Hard Drive Replacement: 手順 6、 3の画像 3
    • Hold the base of the hard drive tray and slide it out and away from its connector.
    • Remove the four Phillips #0 screws from the hard drive tray to free the drive.
    • Install the new drive into the tray, then slide the tray back into the laptop.
    • After inserting your new SSD, apply the thermal pad on top of the area where the connector is.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Deandre Mendes
メンバー登録日: 01/13/22
171 ポイント
1ガイドが承認済み
チーム
York University, Team S-17, Woodhouse Winter 2022 York University, Team S-17, Woodhouse Winter 2022人のメンバー
YORK-WOODHOUSE-W22SSG17
1 メンバー
1のガイドは作成済み
コメント 1 件
Usually, the battery is disconnected before working on the internals of the laptop. While the battery itself is a different model, the instructions for removing the battery connector in Asus VivoBook 14-Inch F412DA Battery Replacement#Release the battery connector worked well for this laptop.
Sohum - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 1,834
