メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus VivoTab Smart Battery Replacement
必要な工具と部品
  1. Asus VivoTab Smart Battery Replacement, Battery: 手順 1、 3の画像 1 Asus VivoTab Smart Battery Replacement, Battery: 手順 1、 3の画像 2 Asus VivoTab Smart Battery Replacement, Battery: 手順 1、 3の画像 3
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Battery Replacement: 手順 2、 3の画像 1 Asus VivoTab Smart Battery Replacement: 手順 2、 3の画像 2 Asus VivoTab Smart Battery Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    • Remove the tape covering the 3 ribbons by peeling it off with your hands or with the tweezers.
    • Carefully detach the ribbons from the device's motherboard by pulling outward using tweezers.
  3. Asus VivoTab Smart Battery Replacement: 手順 3、 3の画像 1 Asus VivoTab Smart Battery Replacement: 手順 3、 3の画像 2 Asus VivoTab Smart Battery Replacement: 手順 3、 3の画像 3
    • The Philips #00 Screwdriver listed in the recommended tools will fit all the screws.
    • Remove the tape covering the areas marked by the black arrows
    • Remove two 3.7 mm Phillips #00 screws
    • Remove eleven 2.7 mm Phillips #00 screws
  4. Asus VivoTab Smart Battery Replacement: 手順 4、 2の画像 1 Asus VivoTab Smart Battery Replacement: 手順 4、 2の画像 2
    • Be careful not to damage the speaker wire.
    • Gently unplug the speaker from the motherboard by grabbing the wire near the plastic white plug with tweezers and gently pulling.
    • Lift up on the speaker with your fingers to remove it.
  5. Asus VivoTab Smart Battery Replacement: 手順 5、 1の画像 1
    • Gently lift the battery pressure plate off of the motherboard.
  6. Asus VivoTab Smart Battery Replacement: 手順 6、 2の画像 1 Asus VivoTab Smart Battery Replacement: 手順 6、 2の画像 2
    • Use tweezers to separate the battery tray from the device
    • Lift the battery tray from the device using your hands.
  7. Asus VivoTab Smart Battery Replacement: 手順 7、 1の画像 1
    • The battery is secured to the tray by a strong adhesive. Take care not to bend the tray when removing the battery.
    • Detach the battery from the tray by pulling the battery up from the tray with your hands.
    • If it is very difficult to lift the battery from the tray, you can use a blow dryer to heat the back side of the tray. This will weaken the adhesive and make it easier to remove.
終わりに
4 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Zach Hatten
メンバー登録日: 10/06/16
563 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 2-4, Sullivan Fall 2016 USF Tampa, Team 2-4, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S2G4
4 メンバー
5のガイドは作成済み
2件のガイドコメント
Hi
So where is the next step ?!
Albert einstein - 返信 共有
Hi
Please answer to me. This is so
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 20
過去 30 日: 89
今までの合計 3,820
