はじめに
Before removing the IO Board you have to remove the back panel. The IO Board is hidden in the bottom right of the device, and is mostly covered.
必要な工具と部品
Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
After removing the back panel, you will see the IO Board under another removable plastic piece.
もう少しです!
終わりに
