メインコンテンツにスキップ
Asus VivoTab Note 8 DC Board Replacement
必要な工具と部品
  1. Asus VivoTab Note 8 DC Board Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. Asus VivoTab Note 8 DC Board Replacement: 手順 2、 2の画像 1 Asus VivoTab Note 8 DC Board Replacement: 手順 2、 2の画像 2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. Asus VivoTab Note 8 DC Board Replacement: 手順 3、 1の画像 1
    • After pulling the panel off, put it to the side.
  4. Asus VivoTab Note 8 DC Board Replacement, Motherboard: 手順 4、 1の画像 1
    • Unplug the battery from the motherboard.
    • Lodge something (a fingernail works fine) under the connecting piece and apply a force straight up and perpendicular to the back of the device.
  5. Asus VivoTab Note 8 DC Board Replacement: 手順 5、 1の画像 1
    • Remove the screws from the black plastic restraint restricting the motherboard's movement using a Phillips #000 screwdriver.
    • Gently remove the black plastic restraint from the motherboard.
  6. Asus VivoTab Note 8 DC Board Replacement: 手順 6、 1の画像 1
    • Remove the six screws holding the motherboard in place using a Phillips #000 screwdriver.
  7. Asus VivoTab Note 8 DC Board Replacement: 手順 7、 1の画像 1
    • Gently pull out the remaining ribbons and cords still plugged into the motherboard.
    • Remove the motherboard from the device.
  8. Asus VivoTab Note 8 DC Board Replacement, DC Board: 手順 8、 2の画像 1 Asus VivoTab Note 8 DC Board Replacement, DC Board: 手順 8、 2の画像 2
    • Remove the two Phillips #000 screws holding the board down.
  9. Asus VivoTab Note 8 DC Board Replacement: 手順 9、 1の画像 1
    • Pull the board up using the opening tool.
  10. Asus VivoTab Note 8 DC Board Replacement: 手順 10、 2の画像 1 Asus VivoTab Note 8 DC Board Replacement: 手順 10、 2の画像 2
    • Pull the DC board away while holding the ribbon cable.
終わりに
作成者
6人の作成者と共同で作成されました。
Ryan Spencer
メンバー登録日: 09/21/18
753 ポイント
6のガイドは作成済み
チーム
University of North Texas, Team 2-7, Raign Spring 2023 University of North Texas, Team 2-7, Raign Spring 2023人のメンバー
UNT-RAIGN-S23S2G7
2 メンバー
6のガイドは作成済み
コメント 1 件
Do you know where to buy the board online? I can't seem to find it anywhere
Chuo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 16
今までの合計 918
