はじめに
This is a step-by-step guide to replacing the DC board in your Asus VivoTab Note 8. The DC board in the Asus VivoTab Note 8 allows you to hear audio straight from the device, and if not in proper shape, may lack quality. This guide will help you replace it if it is broken or damaged, and there are no soldering or special skills required.
必要な工具と部品
Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
Unplug the battery from the motherboard.
Lodge something (a fingernail works fine) under the connecting piece and apply a force straight up and perpendicular to the back of the device.
