必要な工具と部品
First of all you need to remove the 10 screws holding the laptop together.
Then use plastic or metal spudger to separate the bottom cover from the keyboard and touchpad assembly.
Once you open it, carefully unplug the keyboard and touchpad connectors. Be very careful not to damage them!
2 の人々がこのガイドを完成させました。
4 件のコメント
Pls. Do more tutorial like this. It is very helpful to lack of knowledge person ?..
Would you mind to complete your tutorial regarding disassemble / assemble of this laptop model ?
For example : processor replacement
Heat sink replacement LCD replacement
Battery replacement
Hinges replacement
Thanks In Advance !
More Power !
Hello,
Im glad that you found the information useful. Unfortunately this laptop is no longer with me, if I come across the same model again, Ill be sure to make a more advanced tutorial.
Thank you and have a nice day :)
Hello,
This can indicate a problem with the SSD itself and/or the drivers on your laptop. Have you tried to load the drivers manually during Windows installation?
