メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
In the case that your Laptop’s Touchpad stops working, you may need to replace it. This guide shows you how to replace the Touchpad in just a few simple steps.
  1. In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver. There are five 80mm screws.
    • In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
    • There are five 80mm screws.
    • There are four 50mm screws.
    • Pull the back lid off of the laptop using your fingers.
  2. There should be a total of twelve 50mm screws when removing the battery. The battery does not have to be fully removed for this step, however the screws must be taken out and the battery lifted.
    • There should be a total of twelve 50mm screws when removing the battery.
    • The battery does not have to be fully removed for this step, however the screws must be taken out and the battery lifted.
  3. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  4. Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel. Disconnect the LED ribbon wires using a spudger to lift the clamp.
    • Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel.
    • Disconnect the LED ribbon wires using a spudger to lift the clamp.
  5. Using the Phillips #0 screwdriver, remove the  four screws on the silver panel. Using a spudger, gently lift the silver ground strips off of the touch pad.
    • Using the Phillips #0 screwdriver, remove the four screws on the silver panel.
    • Using a spudger, gently lift the silver ground strips off of the touch pad.
    • Pull the touch pad up and towards the battery to remove it from the laptop.
終わりに
Katherine Nasci
メンバー登録日: 2019年04月01日
109 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S9-G9, Wilson Spring 2019 IUPUI, Team S9-G9, Wilson Spring 2019人のメンバー
IUPUI-WILSON-S19S9G9
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 11
今までの合計 273
