メインコンテンツにスキップ
Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement
必要な工具と部品
  1. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Battery: 手順 1、 1の画像 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  2. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 2、 2の画像 1 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 2、 2の画像 2
    • Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
  3. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using a set of precision tweezers, lift the motherboard connector tab.
  4. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 4、 2の画像 1 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 4、 2の画像 2
    • Use a nylon spudger or your fingers to gently pry the battery up.
    • Remove the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): 手順 5、 1の画像 1
    • Use a Phillips #0 screwdriver to remove the nine 50mm panel screws.
    • Gently remove back panel
    • Be aware of sharp metal edges once the panel is removed.
  6. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 6、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  7. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 7、 2の画像 1 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 7、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the five 5mm screws on the fan.
    • Peel the protective wire tape off of the multicolored wires.
  8. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 8、 2の画像 1 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use the precision tweezers to disconnect the wires and gently remove the fan.
    • Be gentle so as not to break wires.
  9. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 9、 2の画像 1 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: 手順 9、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the eight 6mm PCB board screws.
    • Remove the PCB board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Alyssa McFall
メンバー登録日: 09/19/19
376 ポイント
3のガイドは作成済み
チーム
University of North Alabama, Team S1-G4, Winner Fall 2019 University of North Alabama, Team S1-G4, Winner Fall 2019人のメンバー
UNA-WINNER-F19S1G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 335
