メインコンテンツにスキップ
Asus VivoBook E203MA-TBCL432B Keyboard Replacement
必要な工具と部品
  1. Asus VivoBook E203MA-TBCL432B Keyboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 2、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 2、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 2、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 3、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 3、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 3、 3の画像 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Keyboard Replacement, Battery: 手順 4、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement, Battery: 手順 4、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement, Battery: 手順 4、 3の画像 3
    • Now that the back panel is removed you can clearly see the battery and all of its connectors.
    • Begin by removing the silver ribbon cable along the back of the battery.
    • To disconnect it from the motherboard, lift the black tab on the Zero Insertion Force (ZIF) connector up and pull the cable away using the blue tab.
    • Disconnect the ribbon cable from the left side in the same way.
  5. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 5、 1の画像 1
    • Remove the red and black wire along the bottom of the battery.
    • This does not need to be disconnected, only removed from the clamps along the bottom of the battery.
  6. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 6、 2の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 6、 2の画像 2
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws located at the top and left side of the battery.
  7. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 7、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 7、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 7、 3の画像 3
    • Gently lift the battery being mindful of the one cable still connected to the motherboard.
    • With the battery lifted, pull the remaining connector going to the motherboard up, it should come out with little force.
  8. Asus VivoBook E203MA-TBCL432B Keyboard Replacement, Motherboard: 手順 8、 1の画像 1
    • Disconnect the small black and red bundled cable by lifting it directly up from the connector on the motherboard.
  9. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 9、 2の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 9、 2の画像 2
    • Disconnect the black ribbon cable in the center of the motherboard by first lifting the black tab and then pulling the cable free.
  10. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 10、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 10、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 10、 3の画像 3
    • Remove the coaxial connector from the motherboard.
    • Grasp the wire close to where it connects to the motherboard.
    • Pull up and away from the motherboard until the connector is no longer attached to the motherboard.
  11. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 11、 2の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 11、 2の画像 2
    • At the top of the motherboard there is a connector that is taped in place.
    • Peel back the tape so that it is no longer in contact with the motherboard.
    • Gently pull the connector out from its socket.
  12. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 12、 2の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 12、 2の画像 2
    • Now that all the cables are disconnected from the motherboard, you can begin to remove the screws holding the motherboard in place.
    • Use a Philips #0 screwdriver to remove the six 2 mm screws.
  13. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 13、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 13、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 13、 3の画像 3
    • Lift the motherboard away from the computer while allowing the ribbon cable in the middle to fall through its cutout.
  14. Asus VivoBook E203MA-TBCL432B Keyboard Replacement, Keyboard: 手順 14、 2の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement, Keyboard: 手順 14、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the four 2.0 mm screws holding the speakers in place.
    • Carefully pry both of the speakers up from the laptop using the iFixit opening tool as seen in the picture and remove. Only one picture is shown, but it is the same procedure for the other speaker.
    • With both speakers removed, carefully set the speakers off to the side.
  15. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 15、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 15、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 15、 3の画像 3
    この手順で使用する道具:
    購入する
    • At this stage, there should be a ribbon cable exposed.
    • Insert the iFixit opening tool under the white tab on the I/O board and gently pry up to disconnect the ribbon cable.
    • Grab and remove the ribbon cable using the metal tweezers.
  16. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 16、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 16、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 16、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the three 2.0 mm screws highlighted in red.
    • Using the iFixit opening tool, gently lift up on the power button board and remove by hand.
    • Now remove the I/O board by hand as shown. The board should come out with little resistance.
  17. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 17、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 17、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 17、 3の画像 3
    • Insert the iFixit opening tool underneath the cable that is attached to the trackpad to unclip the cable.
    • Using the metal tweezers, remove the ribbon cable and the tape that is attached to the trackpad.
  18. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 18、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 18、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 18、 3の画像 3
    • Using a Phillips #00 screwdriver, remove the three 2.00 mm screws. These screws hold the trackpad in place.
    • Insert the iFixit opening tool under the trackpads frame and carefully pry and pull the frame upwards.
    • With the trackpad frame lifted up by hand, pull the trackpad towards the hinges to remove.
  19. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 19、 3の画像 1 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 19、 3の画像 2 Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 19、 3の画像 3
    • With the metal tweezers, lift the coaxial cable out from its location near the hinge of the screen.
    • Place the assembly at a 90-degree angle (the display is flat on the table and the keyboard is standing up straight).
    • Using a Phillips #0 screwdriver, remove the four 3.00 mm screws.
    • Note: Make sure to have a helper hold the assembly while remove the screws.
  20. Asus VivoBook E203MA-TBCL432B Keyboard Replacement: 手順 20、 1の画像 1
    • The removed keyboard assembly can be seen in this picture. As the keyboard is molded to the plastic frame of the laptop, the entire assembly must be replaced.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Khadijah Sulail
メンバー登録日: 11/16/19
415 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S3-G3, Wilson Fall 2019 IUPUI, Team S3-G3, Wilson Fall 2019人のメンバー
IUPUI-WILSON-F19S3G3
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 1,321
