メインコンテンツにスキップ
Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement
必要な工具と部品
  1. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Back Panel: 手順 1、 1の画像 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 2、 3の画像 1 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 2、 3の画像 2 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 2、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 3、 3の画像 1 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 3、 3の画像 2 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 3、 3の画像 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Headphone Jack and USB Port: 手順 4、 2の画像 1 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement, Headphone Jack and USB Port: 手順 4、 2の画像 2
    • Disconnect the ribbon cable located above the battery.
    • Flip up the locking tab on the Zero Insertion Force (ZIF) connector, then slide the cable away.
  5. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 5、 2の画像 1 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 5、 2の画像 2
    • Disconnect the small white ribbon cable that is connected to the unit that holds the USB and headphone jack.
    • First, lift the white tab that locks onto the blue tab and then pull the cable out by the blue tab.
  6. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 6、 2の画像 1 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 6、 2の画像 2
    • Use the Phillips #0 screwdriver to remove the two 2 mm screws on the top left and bottom left of the component with the headphone jack and USB port.
  7. Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 7、 2の画像 1 Asus VivoBook E203MA-TBCL432B Headphone Jack and USB Port Replacement: 手順 7、 2の画像 2
    • Remove the headphone jack and USB printed circuit board by lifting it directly up and out of the laptop.
終わりに
作成者
3人の作成者と共同で作成されました。
Melanie
メンバー登録日: 03/21/19
280 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team S8-G1, Bailey Spring 2019 UMass Dartmouth, Team S8-G1, Bailey Spring 2019人のメンバー
UMASSD-BAILEY-S19S8G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 600
