メインコンテンツにスキップ
Asus V6800V Wireless Card Replacement
必要な工具と部品
  1. Asus V6800V Wireless Card Replacement, Battery: 手順 1、 2の画像 1 Asus V6800V Wireless Card Replacement, Battery: 手順 1、 2の画像 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Wireless Card Replacement, Wireless Card: 手順 2、 2の画像 1 Asus V6800V Wireless Card Replacement, Wireless Card: 手順 2、 2の画像 2
    • Remove the six screws highlighted on the picture.
    • Once the screws are removed, pry open the panel with the pry tool.
    • It should now look like this.
  3. Asus V6800V Wireless Card Replacement: 手順 3、 2の画像 1 Asus V6800V Wireless Card Replacement: 手順 3、 2の画像 2
    • After removing that panel, locate the screw on the right as highlighted.
    • Remove that screw.
    • Pry open the side panel with the small prying tool as shown.
    • That panel should pop off and the wireless card will now be easily visible.
  4. Asus V6800V Wireless Card Replacement: 手順 4、 1の画像 1
    • Place the small prying tool underneath the gold connector and gently apply pressure straight up until it pops off.
    • Repeat for the other one.
    • Place the gold connectors aside.
  5. Asus V6800V Wireless Card Replacement: 手順 5、 3の画像 1 Asus V6800V Wireless Card Replacement: 手順 5、 3の画像 2 Asus V6800V Wireless Card Replacement: 手順 5、 3の画像 3
    • Locate the tabs that are holding the wireless card in place. These are highlighted in picture.
    • Place one finger on each tab and press each to the side away from the wireless card as shown.
    • The wireless card should pop up as shown. Pull up more with fingers to get more clearance.
  6. Asus V6800V Wireless Card Replacement: 手順 6、 2の画像 1 Asus V6800V Wireless Card Replacement: 手順 6、 2の画像 2
    • To remove the wireless card, pull the card directly out.
    • It should come out with just a little bit of pressure.
    • It should look as shown when removed.
終わりに
作成者
10人の作成者と共同で作成されました。
Steven
メンバー登録日: 06/24/10
32 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S2G9
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 3,839
