はじめに
Removing the keyboard is a useful way to clean it, or it can be replaced if broken.
The keyboard needs to be removed if you wish to remove the top part of the case for further maintenance of the computer.
パーツ
パーツは必要ありません。
First, the screws on the bottom need to be removed first.
  • First, the screws on the bottom need to be removed first.
コメントを追加する
There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
  • There are 4 small tabs holding the keyboard in place. These are located above the F1, F5, F10, and Ins keys. pic 69
コメントを追加する
Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73 Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73
  • Starting on one side, use a finger or small tool to press the tab into the chassis of the computer. The edge of the keyboard will elevate. 72, 73
コメントを追加する
Continue down the keyboard. The keyboard will be noticeably elevated. 82, 83
  • Continue down the keyboard. The keyboard will be noticeably elevated. 82, 83
コメントを追加する
Once all of the tabs are indented, the keyboard will eject itself, remaining elevated. 388
  • Once all of the tabs are indented, the keyboard will eject itself, remaining elevated. 388
コメントを追加する
Partially remove the keyboard by sliding the elevated keyboard towards the screen. Don't remove it all of the way, as we need to remove it's cable first. 389
  • Partially remove the keyboard by sliding the elevated keyboard towards the screen. Don't remove it all of the way, as we need to remove it's cable first. 389
コメントを追加する
To remove the cable holding the keyboard in, flip the keyboard upside down. 391 Using your forefinger and thumb, pinch both sides of the cable and pull away from the connector. 396, 401 You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out. You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out.
  • To remove the cable holding the keyboard in, flip the keyboard upside down. 391 Using your forefinger and thumb, pinch both sides of the cable and pull away from the connector. 396, 401
  • You now have the keyboard separated from the computer. If you wish to clean it, you can use compressed air to blow the dirt out.
コメントを追加する
まとめ
6 の人々がこのガイドを完成させました。
Brian Tubb
メンバー登録日: 2010年06月24日
280 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 2-9, Johann Summer 2010 Cal Poly, Team 2-9, Johann Summer 2010人のメンバー
CPSU-JOHANN-R10S2G9
5 メンバー
11のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 2,184
