メインコンテンツにスキップ
Asus UL80VT Motherboard Replacement
必要な工具と部品
  1. Asus UL80VT Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: 手順 2、 2の画像 1 Asus UL80VT Motherboard Replacement: 手順 2、 2の画像 2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: 手順 3、 1の画像 1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: 手順 4、 3の画像 1 Asus UL80VT Motherboard Replacement, Hard Drive: 手順 4、 3の画像 2 Asus UL80VT Motherboard Replacement, Hard Drive: 手順 4、 3の画像 3
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: 手順 5、 2の画像 1 Asus UL80VT Motherboard Replacement: 手順 5、 2の画像 2
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: 手順 6、 1の画像 1
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: 手順 7、 3の画像 1 Asus UL80VT Motherboard Replacement: 手順 7、 3の画像 2 Asus UL80VT Motherboard Replacement: 手順 7、 3の画像 3
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: 手順 8、 2の画像 1 Asus UL80VT Motherboard Replacement, Keyboard: 手順 8、 2の画像 2
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: 手順 9、 1の画像 1
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: 手順 10、 1の画像 1
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: 手順 11、 1の画像 1
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: 手順 12、 2の画像 1 Asus UL80VT Motherboard Replacement: 手順 12、 2の画像 2
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: 手順 13、 1の画像 1
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: 手順 14、 1の画像 1
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: 手順 15、 1の画像 1
    • Lift the motherboard out of the laptop and remove it from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
James DellaMorte
メンバー登録日: 03/08/19
660 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G5, Botvin Spring 2019 UMass Dartmouth, Team S1-G5, Botvin Spring 2019人のメンバー
UMASSD-BOTVIN-S19S1G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 437
