メインコンテンツにスキップ
Asus U47VC-DS51 Motherboard Replacement
必要な工具と部品
  1. Asus U47VC-DS51 Motherboard Replacement, Hard Drive: 手順 1、 3の画像 1 Asus U47VC-DS51 Motherboard Replacement, Hard Drive: 手順 1、 3の画像 2 Asus U47VC-DS51 Motherboard Replacement, Hard Drive: 手順 1、 3の画像 3
    • Remove the hard drive cover.
    • Unscrew one 8mm Phillips #00 screw.
    • Using the black spudger, insert its flat end under the hard drive's covering, working around to pry it off.
  2. Asus U47VC-DS51 Motherboard Replacement: 手順 2、 3の画像 1 Asus U47VC-DS51 Motherboard Replacement: 手順 2、 3の画像 2 Asus U47VC-DS51 Motherboard Replacement: 手順 2、 3の画像 3
    • Remove the hard drive.
    • Unscrew the four 3mm Phillips #00 screws.
    • Pull the hard drive's black tab away from the laptop to free it.
  3. Asus U47VC-DS51 Motherboard Replacement, Keyboard: 手順 3、 2の画像 1 Asus U47VC-DS51 Motherboard Replacement, Keyboard: 手順 3、 2の画像 2
    • Remove 9 screws from bottom of notebook using PH00 bit + 1 under hard drive bay.
    • Remove 3 screws from bottom of notebook using PH00 bit. 1 is same screw spec as the other 9, and 2 are shorter.
  4. Asus U47VC-DS51 Motherboard Replacement: 手順 4、 2の画像 1 Asus U47VC-DS51 Motherboard Replacement: 手順 4、 2の画像 2
    • Using the black spudger, insert its flat end between the crevice where the color changes from grey to black.
    • The keyboard is very tightly secured.
    • Carefully ease the spudger's end along the crevice, going around the entire frame.
    • The back connectors are short, so be careful when lifting.
  5. Asus U47VC-DS51 Motherboard Replacement: 手順 5、 2の画像 1 Asus U47VC-DS51 Motherboard Replacement: 手順 5、 2の画像 2
    • Lift the keyboard from the front where it is closest to the screen.
    • Disconnect the large and small ZIF connectors attached to the motherboard by flipping the light-colored part of the switch.
  6. Asus U47VC-DS51 Motherboard Replacement: 手順 6、 2の画像 1 Asus U47VC-DS51 Motherboard Replacement: 手順 6、 2の画像 2
    • Remove the third and last ZIF connector on the motherboard by flipping up the dark-colored part of the switch.
    • Now, the component should come completely free.
  7. Asus U47VC-DS51 Motherboard Replacement, Motherboard: 手順 7、 3の画像 1 Asus U47VC-DS51 Motherboard Replacement, Motherboard: 手順 7、 3の画像 2 Asus U47VC-DS51 Motherboard Replacement, Motherboard: 手順 7、 3の画像 3
    • Unscrew the one 8mm screw using a Phillips #00.
    • Using the black spudger, slightly pry up on the tab and gently pull the optical drive away from the laptop in order to remove it.
  8. Asus U47VC-DS51 Motherboard Replacement: 手順 8、 3の画像 1 Asus U47VC-DS51 Motherboard Replacement: 手順 8、 3の画像 2 Asus U47VC-DS51 Motherboard Replacement: 手順 8、 3の画像 3
    • Using the black spudger, slowly lift up on the cable connectors and pull them away from the connectors.
    • Repeat steps on both cables.
    • Unscrew the 12 8mm screws using a Phillips #00 screwdriver.
  9. Asus U47VC-DS51 Motherboard Replacement: 手順 9、 3の画像 1 Asus U47VC-DS51 Motherboard Replacement: 手順 9、 3の画像 2 Asus U47VC-DS51 Motherboard Replacement: 手順 9、 3の画像 3
    • Lift up on the motherboard and disengage the two connectors.
    • Disconnect the cooling fan connector.
    • Unscrew the 7 8mm screws holding in the cooling fan using a Phillips #00 screwdriver.
終わりに
作成者
4人の作成者と共同で作成されました。
Murphy Villegas
メンバー登録日: 01/19/17
207 ポイント
2のガイドは作成済み
チーム
コメント 1 件
Step#3, You need to remove a total of 13 screws from the bottom of the laptop BEFORE prying the keyboard section off the laptop. See pics https://imgur.com/a/h5d1zJ1
danwat1234 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 616
