メインコンテンツにスキップ
Asus U47VC-DS51 Keyboard Replacement
必要な工具と部品
  1. Asus U47VC-DS51 Keyboard Replacement, Keyboard: 手順 1、 2の画像 1 Asus U47VC-DS51 Keyboard Replacement, Keyboard: 手順 1、 2の画像 2
    • Remove 9 screws from bottom of notebook using PH00 bit + 1 under hard drive bay.
    • Remove 3 screws from bottom of notebook using PH00 bit. 1 is same screw spec as the other 9, and 2 are shorter.
  2. Asus U47VC-DS51 Keyboard Replacement: 手順 2、 2の画像 1 Asus U47VC-DS51 Keyboard Replacement: 手順 2、 2の画像 2
    • Using the black spudger, insert its flat end between the crevice where the color changes from grey to black.
    • The keyboard is very tightly secured.
    • Carefully ease the spudger's end along the crevice, going around the entire frame.
    • The back connectors are short, so be careful when lifting.
    You need to remove a total of 13 screws from the bottom of the laptop BEFORE prying the keyboard section off the laptop. See pics  https://imgur.com/a/h5d1zJ1
    danwat1234 - 返信
  3. Asus U47VC-DS51 Keyboard Replacement: 手順 3、 2の画像 1 Asus U47VC-DS51 Keyboard Replacement: 手順 3、 2の画像 2
    • Lift the keyboard from the front where it is closest to the screen.
    • Disconnect the large and small ZIF connectors attached to the motherboard by flipping the light-colored part of the switch.
  4. Asus U47VC-DS51 Keyboard Replacement: 手順 4、 2の画像 1 Asus U47VC-DS51 Keyboard Replacement: 手順 4、 2の画像 2
    • Remove the third and last ZIF connector on the motherboard by flipping up the dark-colored part of the switch.
    • Now, the component should come completely free.
終わりに
作成者
5人の作成者と共同で作成されました。
Brady Roberson
メンバー登録日: 01/18/17
211 ポイント
2のガイドは作成済み
チーム
3 件のコメント
You need to remove a total of 12 screws from the bottom of the laptop BEFORE prying the keyboard section off the laptop. See pics https://imgur.com/a/cNv12A6
danwat1234 - 返信
My keyboard was not removable. I followed all of your instructions, until the last step and when I arrived at the step of removing the old keyboard it was welded at multiple places (lots of places). The original keyboard is not made to be removed and changed. I lost the laptop mouse in the process. Not very happy with this : ( I even thought my laptop was good for garbage, because when I reconnected the connectors, one of them would come apart even after several tries (and I’m very patient). So there.
N Perrier - 返信
The keyboard itself does not come off. But the entire top of the chassis with the keyboard and touchpad come off and can be replaced.
danwat1234 -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 400
