メインコンテンツにスキップ
Asus Transformer T100 Rear Cover Replacement
必要な工具と部品
  1. Asus Transformer T100 Rear Cover Replacement, Rear Cover: 手順 1、 2の画像 1 Asus Transformer T100 Rear Cover Replacement, Rear Cover: 手順 1、 2の画像 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Rear Cover Replacement: 手順 2、 2の画像 1 Asus Transformer T100 Rear Cover Replacement: 手順 2、 2の画像 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    This image seems not to show the correct position where to place the tip of the tool initially. It suggests to pry between the frame and the glass pane from the top of the tablet. That's what I did and broke the glass - one device spoilt. Only the next picture correctly shows where to apply the tool.
    Ole Hoppe - 返信
  3. Asus Transformer T100 Rear Cover Replacement: 手順 3、 1の画像 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Rear Cover Replacement: 手順 4、 2の画像 1 Asus Transformer T100 Rear Cover Replacement: 手順 4、 2の画像 2
    • Remove the rear casing.
終わりに
7 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Taylor Pantiga
メンバー登録日: 04/14/14
1,596 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S13G31
3 メンバー
6のガイドは作成済み
5 件のコメント
This is completely wrong. The outside case of the ASUS T100 is brushed metal.
darimini76 - 返信
there is also a white version, so actually not wrong
Jordi Vanwinkle -
Was able to remove the back cover. Needed to unplug the battery and plug it back in so the the Notebook would boot. It now boots perfectly but
when we replace the back cover it snaps in at the sides and bottom but
WILL NOT Snap in on the top (where the power switch is). All tabs on the back cover and the frame are perfect and not broken but the back cover will not snap closed completely at the top. It still powers on but the power switch sticks and have to press near the switch so it releases in the back cover cavity at the top. Anyone have any ideas on this issue. Thanks
ldajnowski - 返信
I had the same problem. Answer is not to start assemble from the top. Instead, start from the side where there is the SD slot or from the bottom end. Then everything will go. Good luck.
Bac Nguyen Ninh -
Take out your Micro Sd card first!! You will snap it in two!
Milk - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 15,547
