はじめに
This is a guide how to change the Digitizer screen on an asus T-100 transformer book.
  1. In order to get the back cover off, use a tool you are familiar with to pry it open carefully. In order to get the back cover off, use a tool you are familiar with to pry it open carefully. In order to get the back cover off, use a tool you are familiar with to pry it open carefully.
    • In order to get the back cover off, use a tool you are familiar with to pry it open carefully.
  2. Insert a pick, and slowly go around the edge of the tablet to loosen the back shield Insert a pick, and slowly go around the edge of the tablet to loosen the back shield
    • Insert a pick, and slowly go around the edge of the tablet to loosen the back shield
  3. Use a Phillips #1 screw driver to loosen all the screws.
    • Use a Phillips #1 screw driver to loosen all the screws.
    • Make a system to organize the screws, since they have different sizes.
  4. Loosen the tape of the battery connection. Be careful you don't break the wires. They can seem stuck and hard loosen up.
    • Loosen the tape of the battery connection.
    • Be careful you don't break the wires. They can seem stuck and hard loosen up.
    • Separate the cable from the connecter.
  5. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  6. Next step is to peel off the copper tape. Left to Right
    • Next step is to peel off the copper tape. Left to Right
  7. Under the tape is there a connection we have to take off, plus another screw. Under the tape is there a connection we have to take off, plus another screw. Under the tape is there a connection we have to take off, plus another screw.
    • Under the tape is there a connection we have to take off, plus another screw.
  8. Next we have to take out the speaker because it has a connection on the motherboard. In order to get the speaker out you have to lift up the motherboard just a little bit. You can use your finger or any other tool you feel familiar using. In order to get the speaker out you have to lift up the motherboard just a little bit. You can use your finger or any other tool you feel familiar using.
    • Next we have to take out the speaker because it has a connection on the motherboard.
    • In order to get the speaker out you have to lift up the motherboard just a little bit. You can use your finger or any other tool you feel familiar using.
  9. Here we have to disconnect the speaker connection. Here we have to disconnect the speaker connection.
    • Here we have to disconnect the speaker connection.
  10. Next step is a little tricky. We have to disconnect the digitizer. ! Be very careful you don't ruin the closing mechanism. Simply pull back and pull slowly until the connection comes out. Next step is a little tricky. We have to disconnect the digitizer. ! Be very careful you don't ruin the closing mechanism. Simply pull back and pull slowly until the connection comes out.
    • Next step is a little tricky. We have to disconnect the digitizer. ! Be very careful you don't ruin the closing mechanism. Simply pull back and pull slowly until the connection comes out.
  11. We are now ready to take out the motherboard. This is done by following all the steps to this point.
    • We are now ready to take out the motherboard. This is done by following all the steps to this point.
    • Carefully lift the board in both ends or in 2 of the 4 corners and slowly lift it off to the side.
  12. Next step is to take out the LCD. Depending on the model # of your device screws can be placed different corners. Take out the screws and lift out the LCD screen Take out the screws and lift out the LCD screen
    • Next step is to take out the LCD. Depending on the model # of your device screws can be placed different corners.
    • Take out the screws and lift out the LCD screen
  13. The last step is to separate the plastic frame from the old Digitizer glass. I recommend using a heat gun to heat up the glue and then easily separate the old digitizer.
    • The last step is to separate the plastic frame from the old Digitizer glass.
    • I recommend using a heat gun to heat up the glue and then easily separate the old digitizer.
    • You are now ready to put your new digitizer on the plastic frame and assemble the T-100.
    • BE VERY careful when applying heat to the plastic, it can easily bend so make sure you keep your heatgun/hairdryer on low heat.
まとめ
24 の人々がこのガイドを完成させました。
Nick Flor
メンバー登録日: 2015年10月09日
1,774 ポイント
2のガイドは作成済み
Thanks so much for the guide, it was a long process but we'll worth it.
Cody Smith - 返信
Hope it was helpful and that it was detailed enough :) thank you for looking :)
Nick Flor -
Great guide, however I would make one small addition. In the final instructions just a little warning about keeping the heat very low, similar to a hair dryer and take your time. I discovered the hard way that the plastic bezel has quite a low melt/warp temp and I effectively ruined one of the two I was repairing. Sourcing a new digitizer with bezel or bezel alone is proving to be incredibly challenging.
adamstafford - 返信
Thank you for the heads up I will edit that as soon as possible
Nick Flor -
Please, can you give the clearer instructions about 3 different screw sizes, where are they locations. I mixed them up...
Lazeez Karshibayev - 返信
コメントを追加する
統計データを表示:
過去 24時間: 9
過去 7 日: 39
過去 30 日: 234
今までの合計 22,707
