メインコンテンツにスキップ
Asus Transformer T100 Front Facing Camera Board Replacement
必要な工具と部品
  1. Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: 手順 1、 2の画像 1 Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: 手順 1、 2の画像 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Front Facing Camera Board Replacement: 手順 2、 2の画像 1 Asus Transformer T100 Front Facing Camera Board Replacement: 手順 2、 2の画像 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Front Facing Camera Board Replacement: 手順 3、 1の画像 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Front Facing Camera Board Replacement: 手順 4、 2の画像 1 Asus Transformer T100 Front Facing Camera Board Replacement: 手順 4、 2の画像 2
    • Remove the rear casing.
  5. Asus Transformer T100 Front Facing Camera Board Replacement, Front Facing Camera Board: 手順 5、 1の画像 1
    • The camera board is located in the red square in this image.
  6. Asus Transformer T100 Front Facing Camera Board Replacement: 手順 6、 2の画像 1 Asus Transformer T100 Front Facing Camera Board Replacement: 手順 6、 2の画像 2
    • Remove the two screws on the camera board using a Phillips #1 Screwdriver.
  7. Asus Transformer T100 Front Facing Camera Board Replacement: 手順 7、 3の画像 1 Asus Transformer T100 Front Facing Camera Board Replacement: 手順 7、 3の画像 2 Asus Transformer T100 Front Facing Camera Board Replacement: 手順 7、 3の画像 3
    • Lift up the power button cable retention clip on the motherboard and pull the cable out.
  8. Asus Transformer T100 Front Facing Camera Board Replacement: 手順 8、 2の画像 1 Asus Transformer T100 Front Facing Camera Board Replacement: 手順 8、 2の画像 2
    • On the camera connection apparatus, locate the silver tape that connects to the tablet.
    • Peel the silver tape off of the tablet on both sides of the connection apparatus.
    • If this step has been completed correctly, the camera board should be loose, with the tape still attached to the connection apparatus.
  9. Asus Transformer T100 Front Facing Camera Board Replacement: 手順 9、 3の画像 1 Asus Transformer T100 Front Facing Camera Board Replacement: 手順 9、 3の画像 2 Asus Transformer T100 Front Facing Camera Board Replacement: 手順 9、 3の画像 3
    • Gently pull the Orange ribbon cable out of the connection port.
    • This port has no clip. The orange apparatus should slide out with a small tug.
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Taylor Pantiga
メンバー登録日: 04/14/14
1,596 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S13G31
3 メンバー
6のガイドは作成済み
コメント 1 件
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
Alexius Hoopakele Ae - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 3,659
