メインコンテンツにスキップ
Asus Transformer T100 Button Module Replacement
必要な工具と部品
  1. Asus Transformer T100 Button Module Replacement, Rear Cover: 手順 1、 2の画像 1 Asus Transformer T100 Button Module Replacement, Rear Cover: 手順 1、 2の画像 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Button Module Replacement: 手順 2、 2の画像 1 Asus Transformer T100 Button Module Replacement: 手順 2、 2の画像 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
    This image seems not to show the correct position where to place the tip of the tool initially. It suggests to pry between the frame and the glass pane from the top of the tablet. That's what I did and broke the glass - one device spoilt. Only the next picture correctly shows where to apply the tool.
    Ole Hoppe - 返信
  3. Asus Transformer T100 Button Module Replacement: 手順 3、 1の画像 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Button Module Replacement: 手順 4、 2の画像 1 Asus Transformer T100 Button Module Replacement: 手順 4、 2の画像 2
    • Remove the rear casing.
  5. Asus Transformer T100 Button Module Replacement, Button Module: 手順 5、 1の画像 1
    • Unclip the white connection clip using a pair of tweezers.
  6. Asus Transformer T100 Button Module Replacement: 手順 6、 2の画像 1 Asus Transformer T100 Button Module Replacement: 手順 6、 2の画像 2
    • Pull the connection apparatus from the connection clip on the board using a pair of tweezers.
  7. Asus Transformer T100 Button Module Replacement: 手順 7、 1の画像 1
    • Gently fold the connection apparatus back away from your work area.
  8. Asus Transformer T100 Button Module Replacement: 手順 8、 3の画像 1 Asus Transformer T100 Button Module Replacement: 手順 8、 3の画像 2 Asus Transformer T100 Button Module Replacement: 手順 8、 3の画像 3
    • Remove the screws using a Phillips Head #1 screwdriver.
    • Remove the power button module.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Taylor Pantiga
メンバー登録日: 04/14/14
1,596 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 13-31, Maness Spring 2014 Cal Poly, Team 13-31, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S13G31
3 メンバー
6のガイドは作成済み
コメント 1 件
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
Rudolf Guys - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 5,967
