メインコンテンツにスキップ
Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement
必要な工具と部品
  1. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: 手順 1、 3の画像 1 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: 手順 1、 3の画像 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: 手順 1、 3の画像 3
    • Flip the pieces that secure the ribbons to the motherboard up. This is for the front facing camera.
    • Take out the ribbon connected to the motherboard. This is for the rear camera.
    • Note: Only follow what is needed for the camera you are replacing. If both cameras need replacement, do both steps. Otherwise, follow the one designated for the camera you need to replace.
    • Note: The first photo shows the overall image. The second photo shows the step for the front facing camera. The third photo shows the step for the rear camera.
  2. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 2、 1の画像 1
    • Take the cameras out.
    • Note: They are stuck onto the case by little sticky pads.
  3. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: 手順 3、 1の画像 1
    • Put the cameras back into their spot.
    • Note: It’s probably worth it here to make sure they are secure to the case so either re-use the old sticky pads or find some new ones.
終わりに
作成者
5人の作成者と共同で作成されました。
Allison Poh
メンバー登録日: 10/20/15
549 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015人のメンバー
UMASSD-GULBRANDSEN-F15S5G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 302
