メインコンテンツにスキップ
Asus Transformer Book T100TAR Trackpad Replacement
必要な工具と部品
  1. Asus Transformer Book T100TAR Trackpad Replacement, Trackpad: 手順 1、 2の画像 1 Asus Transformer Book T100TAR Trackpad Replacement, Trackpad: 手順 1、 2の画像 2
    • Detach and separate the screen from the keyboard by pressing the silver release button at the base of the tablet.
  2. Asus Transformer Book T100TAR Trackpad Replacement: 手順 2、 3の画像 1 Asus Transformer Book T100TAR Trackpad Replacement: 手順 2、 3の画像 2 Asus Transformer Book T100TAR Trackpad Replacement: 手順 2、 3の画像 3
    • Using a Phillips #0 screwdriver, unscrew six 4mm screws from the rear cover of the keyboard.
    • The rest of the screws for this guide will be Phillips #0 head screws.
    • Use the metal spudger to remove the rubber feet nearest to the top of the keyboard, where the connecting dock to the screen is. There are two 6mm screws under these rubber feet.
  3. Asus Transformer Book T100TAR Trackpad Replacement: 手順 3、 1の画像 1
    • Take the metal spudger and insert it into the seam of the rear cover casing and gently pry upwards.
    • If done correctly, you should feel the clips release.
    • Do not force the clips to release. This will cause them to break, and if broken, the screen will become loose. Open the rear cover gently and with caution.
  4. Asus Transformer Book T100TAR Trackpad Replacement: 手順 4、 1の画像 1
    • Unscrew the screws on the base plate of the keyboard dock. There should be four 4mm screws along the bottom and four 6mm screws along the top, apart from a single 4mm screw (annotated in orange)
  5. Asus Transformer Book T100TAR Trackpad Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    購入する
    • Very carefully remove the black tape holding the metal plate in place.
    • This tape is very sticky, so you might want to use tweezers to get it loose before peeling it off.
  6. Asus Transformer Book T100TAR Trackpad Replacement: 手順 6、 2の画像 1 Asus Transformer Book T100TAR Trackpad Replacement: 手順 6、 2の画像 2
    • Unscrew three 4mm screws holding the trackpad in place and remove the trackpad.
終わりに
作成者
2人の作成者と共同で作成されました。
Alyssa Ballesteros
メンバー登録日: 09/07/16
683 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 6-1, Remmell Fall 2016 USF Tampa, Team 6-1, Remmell Fall 2016人のメンバー
USFT-REMMELL-F16S6G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 8
今までの合計 316
