メインコンテンツにスキップ
Asus Transformer Book T100TAR Motherboard Replacement
必要な工具と部品
  1. Asus Transformer Book T100TAR Motherboard Replacement, Motherboard: 手順 1、 2の画像 1 Asus Transformer Book T100TAR Motherboard Replacement, Motherboard: 手順 1、 2の画像 2
    • Detach and separate the screen from the keyboard by pressing the silver release button at the base of the tablet.
  2. Asus Transformer Book T100TAR Motherboard Replacement: 手順 2、 1の画像 1
    • Take the metal spudger and insert it into the seam of the rear cover casing and gently pry upwards.
    • If done correctly, you should feel the clips release.
    • Ensure that all the clips are released by sliding the metal opening tool along the four edges of the tablet.
    • Do not force the clips to release. This will cause them to break, and if broken, the screen will become loose. Open the rear cover gently and with caution.
  3. Asus Transformer Book T100TAR Motherboard Replacement: 手順 3、 1の画像 1
    • Take off the rear case
  4. Asus Transformer Book T100TAR Motherboard Replacement: 手順 4、 2の画像 1 Asus Transformer Book T100TAR Motherboard Replacement: 手順 4、 2の画像 2
    • Using a plastic opening tool, carefully lift up and detach the large black strip connecting from the camera board to the motherboard.
  5. Asus Transformer Book T100TAR Motherboard Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers, detach the small black cable connected to the motherboard by gently tugging on it.
  6. Asus Transformer Book T100TAR Motherboard Replacement: 手順 6、 3の画像 1 Asus Transformer Book T100TAR Motherboard Replacement: 手順 6、 3の画像 2 Asus Transformer Book T100TAR Motherboard Replacement: 手順 6、 3の画像 3
    • Using tweezers, carefully remove the black tape holding the large orange strip.
    • Using a plastic opening tool, lift up the white tabs and pull the orange strip out of place.
  7. Asus Transformer Book T100TAR Motherboard Replacement: 手順 7、 2の画像 1 Asus Transformer Book T100TAR Motherboard Replacement: 手順 7、 2の画像 2
    • Disconnect the LCD connection apparatus by carefully removing the black protective strip with tweezers and gently tugging on the orange ribbon.
  8. Asus Transformer Book T100TAR Motherboard Replacement: 手順 8、 1の画像 1
    • Using the nylon spudger, very carefully disconnect the battery by gently pushing the sharper end against the base.
    • There should be a small dent in the middle; push from there.
  9. Asus Transformer Book T100TAR Motherboard Replacement: 手順 9、 1の画像 1
    • Using a Phillips #0 screwdriver, unscrew six 5mm screws holding the motherboard in place.
    • Also using a Phillips #0 screwdriver, unscrew two additional 4mm screws off the top left ends of the motherboard.
  10. Asus Transformer Book T100TAR Motherboard Replacement: 手順 10、 1の画像 1
    • Disconnect the speaker from the motherboard by gently tugging on the cable head with tweezers.
  11. Asus Transformer Book T100TAR Motherboard Replacement: 手順 11、 1の画像 1
    • Remove the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alyssa Ballesteros
メンバー登録日: 09/07/16
683 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 6-1, Remmell Fall 2016 USF Tampa, Team 6-1, Remmell Fall 2016人のメンバー
USFT-REMMELL-F16S6G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 928
