メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Asus Transformer Book T100TAM-C1 Motherboard Replacement
必要な工具と部品
  1. Asus Transformer Book T100TAM-C1 Motherboard Replacement, Back Panel: 手順 1、 2の画像 1 Asus Transformer Book T100TAM-C1 Motherboard Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the tablet portion of the device from the keyboard by pushing the large silver button near the base of the tablet. Pull up on the tablet to remove from the keyboard.
  2. Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 2、 2の画像 1 Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 2、 2の画像 2
    • Insert the iFixit Opening Tool into the seam of the back tablet casing and gently pry upwards. With enough force the clips will release on the back tablet casing.
    • Make sure to insert the tool in the seam between the black and gray portions of the backing. If the tool is inserted between the screen and the black portion then the screen may crack.
    • Move the iFixit Opening Tool along the seam until the entire backing is removed.
    • Be careful and try not to use too much force while taking off the backing because you may damage the clips. If you damage the clips the backing will not fit properly back onto the tablet.
  3. Asus Transformer Book T100TAM-C1 Motherboard Replacement, Battery: 手順 3、 1の画像 1
    • Carefully remove the copper tape at the top of the battery.
    • Save this piece of copper tape as you will need it for when you replace the battery.
  4. Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 4、 1の画像 1
    • Gently pull back on the yellow transparent plastic covering on top of the battery connection port.
    • The plastic covering is located at the top right of the battery, next to where the copper tape had been.
  5. Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 5、 1の画像 1
    • Insert the iFixit Opening Tool underneath the top of the battery and gently lift upwards to remove the battery.
  6. Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the battery from the tablet by slowly pulling it from the connected side.
    • The adhesive on the back will pull away from the battery.
    • The battery wire harness will come out as the battery is pulled up.
  7. Asus Transformer Book T100TAM-C1 Motherboard Replacement, Motherboard: 手順 7、 2の画像 1 Asus Transformer Book T100TAM-C1 Motherboard Replacement, Motherboard: 手順 7、 2の画像 2
    • Turn the tablet so that motherboard will be in the top right corner of the tablet and will be the largest of the green pieces.
    • Remove six 5mm Phillips #0 screws around the edge of the motherboard.
    • Remove three 3mm screws on the inner side of the motherboard.
  8. Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 8、 3の画像 1 Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 8、 3の画像 2 Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Locate the 5 different clips around the edges of the motherboard.
    • The clips will be covered by either tape or a foam piece. You will need to remove this before unlatching the clips.
    • Unlatch the connections and use tweezers to remove the cables from the connections.
    • The two remaining connections are slightly different.
  9. Asus Transformer Book T100TAM-C1 Motherboard Replacement: 手順 9、 1の画像 1
    • Pull the connection on the left directly upwards to remove it.
    • Remove the connection on the right by pulling it towards you.
    • The motherboard should now be completely free and able to be removed.
終わりに
作成者
2人の作成者と共同で作成されました。
Brody Moore
メンバー登録日: 09/06/18
813 ポイント
7のガイドは作成済み
チーム
Ohio State, Team S1-G2, Whitney Fall 2018 Ohio State, Team S1-G2, Whitney Fall 2018人のメンバー
OSU-WHITNEY-F18S1G2
2 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 41
今までの合計 664
