メインコンテンツにスキップ
Asus Transformer Book T100TAF Motherboard Replacement
必要な工具と部品
  1. Asus Transformer Book T100TAF Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Detach the screen from the keyboard using the silver button and pulling the screen in the upwards direction.
  2. Asus Transformer Book T100TAF Motherboard Replacement: 手順 2、 1の画像 1
    • Pry the plastic backing off of the tablet using the plastic spudger, releasing all interior clips.
  3. Asus Transformer Book T100TAF Motherboard Replacement: 手順 3、 1の画像 1
    • Unscrew all the silver screws from the motherboard
    • 3.0 mm (3) silver phillips head
  4. Asus Transformer Book T100TAF Motherboard Replacement: 手順 4、 2の画像 1 Asus Transformer Book T100TAF Motherboard Replacement: 手順 4、 2の画像 2
    • Unscrew all the black screws from the motherboard with a PH00 screwdriver
    • 4.5 mm (4) black phillips head
    • 4.5 mm (2) black phillips head
  5. Asus Transformer Book T100TAF Motherboard Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    $3.99
    • Detach the battery cable by steadily pulling it away from the motherboard with angled tweezers.
  6. Asus Transformer Book T100TAF Motherboard Replacement: 手順 6、 1の画像 1
    • Gently pry the orange ribbon cable that is near the battery cable upwards with tweezers.
  7. Asus Transformer Book T100TAF Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the black strip along the top edge, releasing the two sets of connections.
    • Adhesive may hold this strip to the motherboard.
  8. Asus Transformer Book T100TAF Motherboard Replacement: 手順 8、 1の画像 1
    • Use tweezers to detach the black and red twisted pair cable from its connection to the motherboard.
  9. Asus Transformer Book T100TAF Motherboard Replacement: 手順 9、 2の画像 1 Asus Transformer Book T100TAF Motherboard Replacement: 手順 9、 2の画像 2
    • Detach the two thin black wires by grabbing them with tweezers.
  10. Asus Transformer Book T100TAF Motherboard Replacement: 手順 10、 1の画像 1
    • With tweezers, gently flip the white clip up that is holding the white ribbon cable down. Pull the base of the white ribbon cable away from the motherboard with tweezers.
  11. Asus Transformer Book T100TAF Motherboard Replacement: 手順 11、 1の画像 1
    • Disconnect the bottom orange ribbon cable with tweezers by pulling it away from the edge of the device.
  12. Asus Transformer Book T100TAF Motherboard Replacement: 手順 12、 1の画像 1
    • Verify that cables are no longer attached to the motherboard.
  13. Asus Transformer Book T100TAF Motherboard Replacement: 手順 13、 2の画像 1 Asus Transformer Book T100TAF Motherboard Replacement: 手順 13、 2の画像 2
    • Grab the motherboard with two hands, and gently lift it out of the device.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Danielle Nendza
メンバー登録日: 10/03/16
209 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 4-3, Passmore Fall 2016 USF Tampa, Team 4-3, Passmore Fall 2016人のメンバー
USFT-PASSMORE-F16S4G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 23
今までの合計 2,958
