はじめに
This guide will teach you how to remove and replace the touchpad in the event that it is unresponsive or damaged. Special care should be taken with the ribbon cables that need to be removed in the process.
必要な工具と部品
Flip the laptop over so the backside is facing upwards.
Using both hands, slide the lock mechanisms outwards and pull up to remove the battery.
Remove the nine 15.4mm Phillips #00 screws.
Remove the four 8.7mm Phillips #00 screws from the hard drive mounting bracket.
Remove the hard drive bracket.
Remove the ZIF connector ribbon cable from the back of the touchpad by carefully lifting the latch on the connector and sliding the cable out.
ある他の人がこのガイドを完成しました。
