はじめに
The motherboard is connected to everything within the computer, so if it sustains damage, likely the machine will not function smoothly.
If you motherboard has been broken or exposed to water, this guide will show you how to remove it.
必要な工具と部品
Remove the 1.6 mm and 9 mm screws from the back panel using the Phillips #1 screwdriver.
もう少しです!
終わりに
