はじめに
This is a step by step process for the replacement or repair of the webcam on your Asus ROG Strix GL702VS laptop. If you are experiencing bad quality or a black screen while using the webcam, follow these steps to remove the webcam and replace it.
必要な工具と部品
Remove the two screw stickers at the bottom corners of the screen.
Remove the two 4mm JIS #0 screws beneath the stickers.
ある他の人がこのガイドを完成しました。
