メインコンテンツにスキップ
Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement
必要な工具と部品
  1. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: 手順 1、 2の画像 1 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Back Panel: 手順 1、 2の画像 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 手順 2、 3の画像 1 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 手順 2、 3の画像 2 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 手順 2、 3の画像 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Battery: 手順 3、 1の画像 1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 手順 4、 3の画像 1 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 手順 4、 3の画像 2 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement: 手順 4、 3の画像 3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 手順 5、 3の画像 1 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 手順 5、 3の画像 2 Asus ROG Strix GL702VM-BHI7N09 Wifi Card Replacement, Wifi Card: 手順 5、 3の画像 3
    • Using the iFixit Opening Tool, disconnect the black and white coaxial cables from the wifi card.
    • Using a Phillips #1 screwdriver, remove the 4mm retaining screw.
    • Gently slide the wifi card out from the connection slot.
終わりに
作成者
2人の作成者と共同で作成されました。
Alexander Van Auker
メンバー登録日: 09/16/20
79 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 52
今までの合計 2,388
