メインコンテンツにスキップ
Asus ROG Strix GL702VM-BHI7N09 Fan Replacement
必要な工具と部品
  1. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Back Panel: 手順 1、 2の画像 1 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Back Panel: 手順 1、 2の画像 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 2、 3の画像 1 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 2、 3の画像 2 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 2、 3の画像 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement, Fan: 手順 3、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the four indicated 4 mm screws that hold the black fan and the silver one adjacent to it.
  4. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 4、 1の画像 1
    • The smaller black fan must be removed before the larger gray fan on the right can be taken out.
    • To remove the black fan, pull gently on the connecting cables outlined.
  5. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 5、 1の画像 1
    • Unplug the white connector by gently pulling the cables.
    • Lift off the gray fan.
  6. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 6、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the two indicated 4 mm screws from the other gray fan.
  7. Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 7、 3の画像 1 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 7、 3の画像 2 Asus ROG Strix GL702VM-BHI7N09 Fan Replacement: 手順 7、 3の画像 3
    • Unplug the white connector by gently pulling it towards the center of the computer.
    • Lift the fan out of the body of the laptop to remove it.
終わりに
9 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Zach Langer
メンバー登録日: 04/10/17
676 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S13-G2, Forte Spring 2017 Cal Poly, Team S13-G2, Forte Spring 2017人のメンバー
CPSU-FORTE-S17S13G2
4 メンバー
4のガイドは作成済み
8 件のコメント
one of my laptop fans doesn’t work. where can i get a new one? I didn’t see any new fans for this model of laptop for sale anywhere
Mohammadreza Safaee - 返信
محمد رضا جان شما میتونید فن رو باز کنید و مشابهش رو از بازار تهیه کنید
Alireza Soheili -
I was wondering the same. I couldn’t find fans anywhere and after contacting ASUS about them they seemed less than interested in selling me the fans so that I could fix my laptop myself.
Chris Moody - 返信
I got mine from ebay
Shawn Bofenkamp - 返信
Can’t seem to find the fan anywhere
jon_souza - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 17
今までの合計 9,028
