メインコンテンツにスキップ
Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement
必要な工具と部品
  1. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Compartment cover removal: 手順 1、 1の画像 1
    • Lift up rubber tab and unscrew screw, it will stay attached to cover.
    • Pull on tab to pull of cover.
  2. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 1, remove rubber plugs: 手順 2、 3の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 1, remove rubber plugs: 手順 2、 3の画像 2 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 1, remove rubber plugs: 手順 2、 3の画像 3
    • Remove 11 rubber plugs with small straight head screw driver.
    • I place all screws and plugs on a piece of tape sticky side up and label where they go.
  3. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 2, screw removal: 手順 3、 2の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 2, screw removal: 手順 3、 2の画像 2
    • Remove 7, 1cm screws.
    • Remove 5, M2.5x6 screws.
  4. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 3, remove optical drive: 手順 4、 3の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 3, remove optical drive: 手順 4、 3の画像 2 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 3, remove optical drive: 手順 4、 3の画像 3
    • Remove 1, 1/6cm screw.
    • Pull out optical drive.
  5. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 4, screw removal: 手順 5、 2の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 4, screw removal: 手順 5、 2の画像 2
    • Remove 4, 1/4cm screws from bottom row.
    • Remove 3, 1/3cm screws from under where you pulled out optical drive.
  6. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 5, prying front: 手順 6、 3の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 5, prying front: 手順 6、 3の画像 2 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 5, prying front: 手順 6、 3の画像 3
    • Start by using plastic tool by prying open the front center.
    • Stand it up if needed.
    • Work your way to the ends.
  7. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 6, side prying: 手順 7、 3の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 6, side prying: 手順 7、 3の画像 2 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Back panel removal part 6, side prying: 手順 7、 3の画像 3
    • Start by prying the opposite side of the optical drive.
    • There are 2 small tabs that are locked where you pulled the optical drive out, you must unlock them.
    • Unlocking the 2 tabs using two plastic tools. Then continue prying open side.
  8. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Hinge cover removal: 手順 8、 3の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Hinge cover removal: 手順 8、 3の画像 2 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Hinge cover removal: 手順 8、 3の画像 3
    • Pry open the hinge cover with plastic tool. Careful there is a speaker wire attached so open carefully.
    • Disconnect speaker wire.
  9. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Keyboard removal: 手順 9、 3の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Keyboard removal: 手順 9、 3の画像 2 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Keyboard removal: 手順 9、 3の画像 3
    • Once hinge cover is removed and back panel has been pried then turn laptop over and open monitor to extend past 90*.
    • Lift up a little and pull keyboard out about an inch but no more because there are ribbon cables attached underneath .
  10. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Cable detachment: 手順 10、 3の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Cable detachment: 手順 10、 3の画像 2 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Cable detachment: 手順 10、 3の画像 3
    • Slowly lift up keyboard to see the 4 ribbon cables and carefully pry up tabs where cables are connected.
  11. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, Battery wires disconnected: 手順 11、 1の画像 1
    • Grab wires in middle and pull and wiggle gently to pull out wires from connection.
  12. Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, RAM removal: 手順 12、 3の画像 1 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, RAM removal: 手順 12、 3の画像 2 Asus ROG Laptop G752VL-DH71 RAM under keyboard Replacement, RAM removal: 手順 12、 3の画像 3
    • Notice to tabs on each side of RAM, pry them to the side.
    • When both tabs are pried to the side the RAM should pop up.
    • By grabbing the RAM on the sides, remove RAM.
終わりに
8 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Corbin Schon
メンバー登録日: 01/26/16
593 ポイント
2のガイドは作成済み
3 件のコメント
Thanks for this guide! I purchased some RAM and an SSD and wanted to upgrade my laptop. The instructions were clear, and I was able to follow along to max out my laptop’s RAM at 64GB. All I needed was a size #0 phillips head, and a couple of spudgers.
Menelik Seth - 返信
I’m glad it could help!
Thanks for the feedback.
Corbin Schon -
any suggestion on cable removal wish I could get a picture to enlarge seems to be the only worry area for me
any instructions on how to remove the cable I see what look like tabs or is there some kind of release
joe kamer - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 3,534
