はじめに
Use this guide to replace the hard drive in your device.
  1. Lift up the rubber tab located in the upper-right corner of the backing plate.
    • Lift up the rubber tab located in the upper-right corner of the backing plate.
  2. Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
    • Use a Phillips #1 screwdriver to remove the 5.2 mm screw behind the rubber tap.
    • Carefully pull the backing plate off. If you have a pry tool, you can pry on the edges carefully.
    • Use a Phillips head screwdriver to remove the four 2.4 mm screws from the hard drive mount.
    • Remove the hard drive from the device.
まとめ
Anum Haidari
メンバー登録日: 2018年10月22日
533 ポイント
3のガイドは作成済み
チーム
UC Davis, Team S7-G4, Lore Fall 2018 UC Davis, Team S7-G4, Lore Fall 2018人のメンバー
UCD-LORE-F18S7G4
2 メンバー
3のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 34
