はじめに
This guide demonstrates the step-by-step removal of the Asus ROG G751JL-DS71 screen. Before proceeding, unplug your device from its power source.
必要な工具と部品
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
Lift away the metal housings from each side of the laptop.
ある他の人がこのガイドを完成しました。
