はじめに
This guide will show the user how to safely remove and replace the battery.
必要な工具と部品
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver.
Use a pair of tweezers to remove the top four rubber stoppers found on the bottom of the laptop.
Use a Phillips 1 Screwdriver to remove the four 6.8 mm screws underneath the back panel.
Lift away the metal housings from each side of the laptop.
Disconnect the pin connector that attaches the battery to the motherboard.
Use a Phillips 1 Screwdriver to remove the two 5.4 mm screws.
7 の人々がこのガイドを完成させました。
3 件のコメント
Can yo please share the review of this battery? Should I go for original battery or ifixit battery?
Thank you so much for this Aurora it really helped me work on my ROG, hope my extra notes on Section 11 & 12 help others! Blessings!
I have a G751JT-CH71 & I'm not sure if the models are slightly different but I cannot remove the battery by simply lifting it out of the compartment. The battery has 4 lock-in tabs towards the back of the laptop AND 2 additional tabs that are beneath the board. I'm going to carefully pry the battery out, but I'm unsure if there's a recommended method to prying the battery out…
