はじめに
It is important to power down the Asus ROG G751JL-BSI7T28 prior to starting the repair as well as unplug the A/C adapter. While this covers most of the concern with electrical components, there still may be connectors with power going through them. There is no risk for a personal shock however no metal should be near the laptop during the repair. Necklaces, bracelets, rings, etc could potentially short out components on the motherboard of the laptop making your problem bigger than when you started the repair!
When replacing the speakers, it is important not to damage the drivers on the new speakers. This will severely distort the sound. It is also important to be careful with the pins that connect the speaker to the board. These long metal pins may bend and could be troublesome to straighten back out.
必要な工具と部品
With the laptop closed, turn it upside-down so the bottom is facing up toward you.
Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
Remove the keyboard from the laptop.
Flip the SD card reader's retaining arm up.
Remove the SD card reader's power/data ribbon cable.
