メインコンテンツにスキップ
Asus ROG G751JL-BSI7T28 Speaker Replacement
必要な工具と部品
  1. Asus ROG G751JL-BSI7T28 Speaker Replacement, Back Panel: 手順 1、 1の画像 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 2、 3の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 2、 3の画像 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 2、 3の画像 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Speaker Replacement, Display Assembly: 手順 3、 2の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement, Display Assembly: 手順 3、 2の画像 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 4、 2の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 4、 2の画像 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 5、 3の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 5、 3の画像 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 5、 3の画像 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 6、 3の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 6、 3の画像 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 6、 3の画像 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 7、 2の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 7、 2の画像 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
  8. Asus ROG G751JL-BSI7T28 Speaker Replacement, Keyboard Assembly: 手順 8、 2の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement, Keyboard Assembly: 手順 8、 2の画像 2
    • Carefully lift the keyboard up, being careful to not damage the fragile ribbon connectors.
    • Use an opening tool to detach the ribbon cables connecting the keyboard to the rest of the laptop.
    • Remove the keyboard from the laptop.
  9. Asus ROG G751JL-BSI7T28 Speaker Replacement, Speaker: 手順 9、 2の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement, Speaker: 手順 9、 2の画像 2
    • Flip the SD card reader's retaining arm up.
    • Remove the SD card reader's power/data ribbon cable.
  10. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 10、 3の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 10、 3の画像 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 10、 3の画像 3
    • Remove the speaker's power/data cable.
  11. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 11、 2の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 11、 2の画像 2
    • Remove four 3mm Phillips #0 screws from the speaker.
    • Remove three 3mm Phillips #0 screws from the SD card reader.
  12. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 12、 3の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 12、 3の画像 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 12、 3の画像 3
    • Remove the SD card reader.
  13. Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 13、 3の画像 1 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 13、 3の画像 2 Asus ROG G751JL-BSI7T28 Speaker Replacement: 手順 13、 3の画像 3
    • Remove the speaker from the laptop.
終わりに
作成者
3人の作成者と共同で作成されました。
Dylan Michael Leonard
メンバー登録日: 11/05/19
423 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S1-G1, Barthe Fall 2019 UMass Dartmouth, Team S1-G1, Barthe Fall 2019人のメンバー
UMASSD-BARTHE-F19S1G1
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 9
今までの合計 197
