メインコンテンツにスキップ
Asus ROG G751JL-BSI7T28 Display Assembly Replacement
必要な工具と部品
  1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Back Panel: 手順 1、 1の画像 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 2、 3の画像 1 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 2、 3の画像 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 2、 3の画像 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: 手順 3、 2の画像 1 Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: 手順 3、 2の画像 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 4、 2の画像 1 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 4、 2の画像 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 5、 3の画像 1 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 5、 3の画像 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 5、 3の画像 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 6、 3の画像 1 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 6、 3の画像 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 6、 3の画像 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 7、 2の画像 1 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: 手順 7、 2の画像 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
終わりに
作成者
5人の作成者と共同で作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
91,937 ポイント
241のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,433のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 384
