はじめに
This guide will attempt to show the user how to safely remove and replace the keyboard without damaging any of the surrounding components.
必要な工具と部品
Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
Pry the door up to release the clips closest to the pick.
Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
Remove the ten 5.2 mm screws holding the main panel in place, highlighted in the photo, with a Phillips screwdriver.
Remove the four 5.2 mm screws underneath the center panel, highlighted in the photo, with a Phillips screwdriver.
4 の人々がこのガイドを完成させました。
コメント 1 件
Great work, but you are missing the last few steps of the replacement as all you are showing is how to remove the upper assembly
