メインコンテンツにスキップ
はじめに
Use this guide if you are having troubles getting your speakers to work at optimal performance or if there is no sound coming out of your speakers at all.
パーツ
パーツは指定されていません。
  1. Using a plastic opening tool, remove the two rubber tabs circled in red. Using a plastic opening tool, remove the two rubber tabs circled in red.
    • Using a plastic opening tool, remove the two rubber tabs circled in red.
  2. Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed. Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
    • Remove both of the 8mm Phillips #2 screws from these slots where the rubber caps were removed.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Slide the tab to pop the battery out of its holder. Pull the battery out of its slot.
    • Slide the tab to pop the battery out of its holder.
    • Pull the battery out of its slot.
  5. Remove the three 4mm Phillips #2 screws from the open battery slot as shown. Remove the two 5mm Phillips #2 screws.
    • Remove the three 4mm Phillips #2 screws from the open battery slot as shown.
    • Remove the two 5mm Phillips #2 screws.
  6. Begin prying up on the plate as shown in the pictures. Begin prying up on the plate as shown in the pictures. Begin prying up on the plate as shown in the pictures.
    • Begin prying up on the plate as shown in the pictures.
  7. Detach the single connector using your plastic opening tool.
    • Detach the single connector using your plastic opening tool.
    • Remove the speaker bar.
まとめ
Tanner
メンバー登録日: 2018年09月21日
788 ポイント
5のガイドは作成済み
チーム
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 77
