はじめに
This guide covers how to replace the RAM for the Asus ROG G750JH-DB71.
The RAM provides memory for the Asus ROG G750JH-DB71 while running the operating system. This allows the Asus ROG G750JH-DB71 to do many tasks from taxing videogames and programs to browsing the internet. Damage to Asus ROG G750JH-DB71's RAM could cause random crashing or a slow operating system.
To test if it's your RAM is causing these problems you can test this using free diagnostic programs on the internet.
The Asus ROG G750JH-DB71 comes with a 12 GB DDR3-SDRAM and 24 GB of RAM in total. You can add up to 32 GB of RAM (32000 MB)
必要な工具と部品
Use a spudger or your finger to lift up the plastic cover on the bottom of the laptop.
Under the plastic cover is a captive screw; unscrew it using a Phillips #00 screwdriver.
The RAM module is located directly in the center of the computer on top of the motherboard.
Push in the two levers on each side of the RAM module. This frees the module from the slot and allows removal.
Once loose, pull the RAM module away from the slot at a 45 degree angle as to not damage it.
