メインコンテンツにスキップ
Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement
必要な工具と部品
  1. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 手順 1、 3の画像 1 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 手順 1、 3の画像 2 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Battery: 手順 1、 3の画像 3
    • With your right hand, push the latch completely up to where you can see the battery pop slightly up. Pick and pull at the tab with your left hand.
    • You can now fully remove the battery from the device.
  2. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: 手順 2、 2の画像 1 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement, Track Pad Buttons: 手順 2、 2の画像 2
    • Remove the large flathead screw holding the back cover in place.
    • Pull the cover off by prying it open starting from the top center and moving outwards.
  3. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 3、 2の画像 1 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 3、 2の画像 2
    • Remove the eight short screws holding in the two metal covers near the bottom.
    • Remove the two metal covers.
  4. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 4、 2の画像 1 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 4、 2の画像 2
    • Remove the battery to access the screws under it.
    • Remove these 16 screws with a regular Phillips head screw-driver.
    • These Phillips head screws will require a longer bit or an extension.
  5. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 5、 2の画像 1 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 5、 2の画像 2
    • Flip the device back over.
    • Pull off the plastic cover behind the screen.
    • Remove the four Phillips head screws holding the screen in place.
  6. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 6、 2の画像 1 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 6、 2の画像 2
    • With the screen removed, pry the piece that has the keyboard and the track pad on it.
  7. Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 7、 2の画像 1 Asus ROG G74SX-DH73-3D Track Pad Buttons Replacement: 手順 7、 2の画像 2
    • Remove the two Phillips head screws holding the buttons in place.
終わりに
作成者
2人の作成者と共同で作成されました。
Josh Reyes
メンバー登録日: 09/18/18
183 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S3-G7, Raign Fall 2018 University of North Texas, Team S3-G7, Raign Fall 2018人のメンバー
UNT-RAIGN-F18S3G7
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 369
