メインコンテンツにスキップ
Asus Q551L Repair Motherboard Replacement
必要な工具と部品
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: 手順 1、 2の画像 1 Asus Q551L Repair Motherboard Replacement, Back Panel: 手順 1、 2の画像 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: 手順 3、 2の画像 1 Asus Q551L Repair Motherboard Replacement, Battery: 手順 3、 2の画像 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: 手順 4、 2の画像 1 Asus Q551L Repair Motherboard Replacement: 手順 4、 2の画像 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive: 手順 5、 3の画像 1 Asus Q551L Repair Motherboard Replacement, Optical Drive: 手順 5、 3の画像 2 Asus Q551L Repair Motherboard Replacement, Optical Drive: 手順 5、 3の画像 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: 手順 6、 3の画像 1 Asus Q551L Repair Motherboard Replacement, Motherboard: 手順 6、 3の画像 2 Asus Q551L Repair Motherboard Replacement, Motherboard: 手順 6、 3の画像 3
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: 手順 7、 2の画像 1 Asus Q551L Repair Motherboard Replacement: 手順 7、 2の画像 2
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: 手順 8、 3の画像 1 Asus Q551L Repair Motherboard Replacement: 手順 8、 3の画像 2 Asus Q551L Repair Motherboard Replacement: 手順 8、 3の画像 3
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Baker
メンバー登録日: 01/17/18
300 ポイント
1ガイドが承認済み
チーム
コメント 1 件
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 17
今までの合計 2,370
