はじめに
The motherboard is the most impotent part in the computer because most of the computer's parts are located on it or attached to it, so you will need to remove them in order to replace the motherboard. Watch out for some wires because they are hard to see.
必要な工具と部品
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
Remove the fan by unscrewing the nine screws shown in the images.
The four colored wire and the black cable need to be pulled out gently.
2 の人々がこのガイドを完成させました。
コメント 1 件
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
