メインコンテンツにスキップ
Asus Q534U CPU Fan/Heat Sink Replacement
必要な工具と部品
  1. Asus Q534U CPU Fan/Heat Sink Replacement, Back Case Removal: 手順 1、 1の画像 1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U CPU Fan/Heat Sink Replacement: 手順 2、 2の画像 1 Asus Q534U CPU Fan/Heat Sink Replacement: 手順 2、 2の画像 2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U CPU Fan/Heat Sink Replacement: 手順 3、 2の画像 1 Asus Q534U CPU Fan/Heat Sink Replacement: 手順 3、 2の画像 2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U CPU Fan/Heat Sink Replacement: 手順 4、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: 手順 5、 2の画像 1 Asus Q534U CPU Fan/Heat Sink Replacement, CPU Fan/Heat Sink: 手順 5、 2の画像 2
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  6. Asus Q534U CPU Fan/Heat Sink Replacement: 手順 6、 2の画像 1 Asus Q534U CPU Fan/Heat Sink Replacement: 手順 6、 2の画像 2
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
mmedina
メンバー登録日: 04/07/16
749 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 UMass Dartmouth, Team S66-G6, Rockett Fall 2017人のメンバー
UMASSD-ROCKETT-F17S66G6
3 メンバー
5のガイドは作成済み
コメント 1 件
Is it possible to replace the fan only without removing the full heatsink or is it fused together as one unit?
Bork Bois - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 29
今までの合計 2,895
