メインコンテンツにスキップ
Asus Q505UA-BI5T7 Screen Replacement
必要な工具と部品
  1. Asus Q505UA-BI5T7 Screen Replacement, Back Cover: 手順 1、 2の画像 1 Asus Q505UA-BI5T7 Screen Replacement, Back Cover: 手順 1、 2の画像 2
    • Flip the device over so that the back cover is facing you.
    • Ensure that the device is turned off.
    • Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
    • Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
  2. Asus Q505UA-BI5T7 Screen Replacement: 手順 2、 3の画像 1 Asus Q505UA-BI5T7 Screen Replacement: 手順 2、 3の画像 2 Asus Q505UA-BI5T7 Screen Replacement: 手順 2、 3の画像 3
    • Use the plastic opening tool to gently pry the back cover of the laptop up. Slide the tool slowly along the edges of the back cover to pop it out of the clips holding the cover in place.
  3. Asus Q505UA-BI5T7 Screen Replacement: 手順 3、 1の画像 1
    • Gently remove the cover and lift it off of the back of the device.
  4. Asus Q505UA-BI5T7 Screen Replacement, Battery: 手順 4、 2の画像 1 Asus Q505UA-BI5T7 Screen Replacement, Battery: 手順 4、 2の画像 2
    • Make sure your device is turned off. Remove the 5 mm screws on each respective side of the battery by twisting counter-clockwise with a #0 Phillips screwdriver.
  5. Asus Q505UA-BI5T7 Screen Replacement: 手順 5、 3の画像 1 Asus Q505UA-BI5T7 Screen Replacement: 手順 5、 3の画像 2 Asus Q505UA-BI5T7 Screen Replacement: 手順 5、 3の画像 3
    • Use a plastic opening tool to gently pry off the connected panel.
  6. Asus Q505UA-BI5T7 Screen Replacement: 手順 6、 1の画像 1
    • Gently lift the battery.
  7. Asus Q505UA-BI5T7 Screen Replacement, Screen: 手順 7、 3の画像 1 Asus Q505UA-BI5T7 Screen Replacement, Screen: 手順 7、 3の画像 2 Asus Q505UA-BI5T7 Screen Replacement, Screen: 手順 7、 3の画像 3
    • After following the battery removal guide, use your Ifixit opening tool to pry the two screen connectors off of the laptop motherboard.
    • The screen connector next to the fan must be unwrapped from around the fan so it is free
  8. Asus Q505UA-BI5T7 Screen Replacement: 手順 8、 3の画像 1 Asus Q505UA-BI5T7 Screen Replacement: 手順 8、 3の画像 2 Asus Q505UA-BI5T7 Screen Replacement: 手順 8、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the three 5 mm screws securing each hinge on the laptop.
  9. Asus Q505UA-BI5T7 Screen Replacement: 手順 9、 1の画像 1
    • Then, gently open the screen a bit and remove the screen from the hinges, being careful with the screen connectors.
  10. Asus Q505UA-BI5T7 Screen Replacement: 手順 10、 3の画像 1 Asus Q505UA-BI5T7 Screen Replacement: 手順 10、 3の画像 2 Asus Q505UA-BI5T7 Screen Replacement: 手順 10、 3の画像 3
    • After removing the screen from the laptop, use a metal pry tool to get within the gap of the screen and the casing.
    • Go all around the screen with the pry tool and detach and lift the screen from the casing.
  11. Asus Q505UA-BI5T7 Screen Replacement: 手順 11、 3の画像 1 Asus Q505UA-BI5T7 Screen Replacement: 手順 11、 3の画像 2 Asus Q505UA-BI5T7 Screen Replacement: 手順 11、 3の画像 3
    • Using your Ifixit opening tool, remove the camera stuck on with an adhesive strip off of the top of the screen.
    • Using the same tool, pry and unclip the bottom touchscreen module from the screen.
    • Before removing the module from the screen, unclip the two ribbon cables still keeping it tethered.
    • Be sure to be careful with the ribbon cables so as to not tear them.
    • You can now remove the touchscreen module connected to the camera from the old screen and transfer it to your new one.
終わりに
作成者
1人の作成者と共同作成されました。
Ivan Melgar
メンバー登録日: 09/27/23
121 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team 1-2, Karnes Fall 2023 Linn Benton Community College, Team 1-2, Karnes Fall 2023人のメンバー
LBCC-KARNES-F23S1G2
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 73
