メインコンテンツにスキップ
Asus Q504UA-BHI5T13 Touch-pad Replacement
必要な工具と部品
  1. Asus Q504UA-BHI5T13 Touch-pad Replacement, Back Panel: 手順 1、 1の画像 1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 2、 1の画像 1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 3、 1の画像 1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 4、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 5、 1の画像 1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Touch-pad Replacement, Battery: 手順 6、 1の画像 1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 7、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 8、 2の画像 1 Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 8、 2の画像 2
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 9、 2の画像 1 Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 9、 2の画像 2
    • Remove the battery from the device.
  10. Asus Q504UA-BHI5T13 Touch-pad Replacement, Touch-pad: 手順 10、 1の画像 1
    • Pull the large data ribbon near the touch-pad out of the way with your hands.
    • Use the Phillips #0 screwdriver to remove the three 3.0 mm screws connecting the touch-pad to the device.
  11. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 11、 2の画像 1 Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 11、 2の画像 2
    • Use the small plastic opening tool to remove the ZIF Connector on the left side of the touch-pad.
  12. Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 12、 2の画像 1 Asus Q504UA-BHI5T13 Touch-pad Replacement: 手順 12、 2の画像 2
    • Pry the end closest to the display up with your fingers and pull the touch-pad out.
終わりに
作成者
3人の作成者と共同で作成されました。
Jacob Fritsch
メンバー登録日: 11/04/19
337 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S1-G2, Henning Fall 2019 IUPUI, Team S1-G2, Henning Fall 2019人のメンバー
IUPUI-HENNING-F19S1G2
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 283
