メインコンテンツにスキップ
Asus Q504UA-BHI5T13 Speaker Replacement
必要な工具と部品
  1. Asus Q504UA-BHI5T13 Speaker Replacement, Back Panel: 手順 1、 1の画像 1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 2、 1の画像 1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 3、 1の画像 1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 4、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 5、 1の画像 1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Speaker Replacement, Battery: 手順 6、 1の画像 1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 7、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 8、 2の画像 1 Asus Q504UA-BHI5T13 Speaker Replacement: 手順 8、 2の画像 2
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 9、 2の画像 1 Asus Q504UA-BHI5T13 Speaker Replacement: 手順 9、 2の画像 2
    • Remove the battery from the device.
  10. Asus Q504UA-BHI5T13 Speaker Replacement, Speaker: 手順 10、 1の画像 1
    • We will start with the left speaker. The left speaker is the one with the letter “L” on it. Use the Phillips #0 screwdriver to remove the two 4mm screws around the left speaker.
    • It shares the bottom screw with the battery.
    • This is the screw that is shared with the battery. This screw will be removed once the battery is removed.
  11. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 11、 2の画像 1 Asus Q504UA-BHI5T13 Speaker Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to pull the plug towards the speaker.
    • Take care when removing the cable. Damaging the cable will stop the part from working.
  12. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 12、 2の画像 1 Asus Q504UA-BHI5T13 Speaker Replacement: 手順 12、 2の画像 2
    • Unhook the red and black twisted wire from the tabs that are between the two speakers. This prevents damage to the wires as the speakers are removed.
    • Remove the Left (L) speaker.
  13. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 13、 1の画像 1
    • Now for the right speaker, use the Phillips #0 screwdriver to remove the two 4mm screws around the speaker.
    • It shares the bottom screw with the motherboard.
    • This screw is shared with the mother board, this screw will need to be removed however the mother board does not need to be removed before the speaker.
  14. Asus Q504UA-BHI5T13 Speaker Replacement: 手順 14、 1の画像 1
    • Remove the Right (R) speaker from the device. Using a spudger helps to slide it out.
終わりに
作成者
6人の作成者と共同で作成されました。
Joel Joly
メンバー登録日: 10/02/17
129 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S10-G4, Thompson Fall 2017 USF Tampa, Team S10-G4, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S10G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 300
