はじめに
This guide will show you how to remove the heat sink from the Asus Q504UA-BHI5T13.
The heat sink is a vital part of a laptop that ensures proper CPU cooling. In cases of heat sink fan damage, the part will need to be replaced. Completion of this guide may be up to 25 minutes or longer. It is also recommended to have some experience with electronics before attempting this guide.
Note:
When removing the screws attached to the heat sink, follow the proper order, provided by the guide at that step, to avoid damage to the heat sink. Further, handle the heat sink with care, the copper coils may be easy to damage.
Before attempting this guide, power down the device and remove all external peripherals and charging cords.
必要な工具と部品
Once the back cover is removed, have the laptop facing upside down with the hinges facing nearest to you.
ある他の人がこのガイドを完成しました。
