メインコンテンツにスキップ
Asus Q504UA-BHI5T13 Hard Drive Replacement
必要な工具と部品
  1. Asus Q504UA-BHI5T13 Hard Drive Replacement, Back Panel: 手順 1、 1の画像 1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Hard Drive Replacement: 手順 2、 1の画像 1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Hard Drive Replacement: 手順 3、 1の画像 1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Hard Drive Replacement: 手順 4、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Hard Drive Replacement: 手順 5、 1の画像 1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Hard Drive Replacement, Hard Drive: 手順 6、 1の画像 1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Hard Drive Replacement: 手順 7、 1の画像 1
    • Use the Phillips #0 screwdriver to remove the eight 4mm screws around the hard drive casing (located next to the Right [R] speaker).
    • Start off with the four black outer screws so that the casing can be released from the laptop unit.
    • The next sequence of screws to remove are the four silver screws.
  8. Asus Q504UA-BHI5T13 Hard Drive Replacement: 手順 8、 1の画像 1
    • Remove the cover.
  9. Asus Q504UA-BHI5T13 Hard Drive Replacement: 手順 9、 2の画像 1 Asus Q504UA-BHI5T13 Hard Drive Replacement: 手順 9、 2の画像 2
    • Lift the hard drive and disconnect the hard drive sliding connector.
    • Be careful when removing the connector from the hard drive, as damaging that cable could cause damage to the hard drive.
終わりに
5 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Johnathan Teav
メンバー登録日: 10/02/17
456 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S10-G4, Thompson Fall 2017 USF Tampa, Team S10-G4, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S10G4
4 メンバー
5のガイドは作成済み
コメント 1 件
I used your steps to replace the 128GB SSD with a larger drive. When I booted up, the new SSD appeared, the REMOVED 128GB SSD appeared, but the 1TB HHD data drive disappeared. Any tho’ts? Wish I could give you more than 30 points. Thanks. I was down to 17GB on the original drive.
Mark Mikrut - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 32
今までの合計 5,920
